Thank you for version 5.0. I was looking foreward to be able to import outlook .pst-files, but i doesn’t seem to work. When I try all I get is an empty trash-folder. Can anyone help?
What option did you use? Import whole accounts or Import selected PST file?
I used the ‘Import selected PST file’-option
Are you sure that the PST file contains any messages? Did you check all the folders you want to import?
I asked yo ufor the PST file but I have one additional question - did you tick all the folders you want to import?
Hi, I select the PST them, after processing something, it shows only one folder (deleted items) with cero elements. THX!
OK, I will test the PST file and will let you know the result. Did you send it?
Yes, I sent it to Tomas. Thx!
Tomas told me that it has been already internally fixed so you can expect it in the next update.
