Bonjour,
J’ai un problème avec l’un de mes compte mails. Du jour au lendemain celui-ci ne se synchronise plus. Il y a l’icône du point d’exclamation sur triangle rouge à côté du compte. Je n’ai rien changer dans mes paramètres. Mes autre comptes mail continue à fonctionner très bien et ce compte continue à se synchroniser sur l’application mobile.
J’ai la version d’EM Client 10.4.5606 (58d51c0) sous windows 11.
Merci de votre aide
If its only with that one account thats not synching on your desktop but your mobile syncs that same mail account ok, then could be your physical connection from the desktop to that specific mail server might be the cause if its different than the mobile. So if it is different, then suggest to shutdown your computer and modem for say 2 mins and then turn back on and see if it works.
However if your mobile is using the same wifi data modem connection as your desktop, then suggest to go to “Menu / Accounts” and remove and re-add that specific mail account and see if that fixes it as could possible be a corrupted account and just need removing and re-adding.
If its a POP account “before removing” go to "Menu / File / Export and export any emails, contacts, tasks etc you need to your desktop or downloads so you can then reimport them later after re-adding the account via “Menu / File / Import”.
Alternatively if you have been making regularly eM Client backups and have a recent dated backup when you know that account was synching ok, go to “Menu / File / Restore” and restore your backup. Once restored any emails since the restore point will update when eM Client syncs.
If you still get the same red error on that account even after removing and re-adding or restoring a backup, then “click the dropdown on the right of Refresh” and click “Show Operations” and click the “Log Tab” and look for any obvious error messages and paste them in this thread. We might then be able to see whats wrong. Blank out anything personal in the errors.
