Problem with notes and ALT+O
In eM Client 10 when I want to add note, I can’t type “ó” (right alt + “o” in polish keyboard layout), because it closes note window.
I am not able to reproduce that.
If you have any issues while testing the beta version, please report them to [email protected]
Include the beta version you are using (Menu > Help > About) and the provider where the Notes are saved (Gmail, Exchange, etc.).
Do you have polish (programmer) keyboard layout installerd?
If not - you’ll not be able to reproduce that.
It’s layout using in PL.
(BTW. I wrote this in my post - right alt + “o” in polish keyboard layout)
I wrote to [email protected] because I’m not sure if it is a problem with eM Client 10 or eM Client 9 and is impossible to use both versions on one computer.
