I’m having two problems with IMAP. My main account has always been a POP3 account, but earlier this year I converted it to IMAP, and since then I seem to have had a few problems. Firstly, it seems that the body of the mail doesn’t get picked up sometimes; I move the selector bar to an email (in the top window) and expect to see the preview in the bottom, but this doesn’t happen; instead, I see three or four dots racing across the screen from left to right, recurring again and again. Sometimes the mail shows itself after a minute or two, sometimes I get fed up waiting, and sometimes it just seems to get stuck.
The other problem is that I keep getting error messages similar to the following:
01:45:59 Rogers IMAP [CalDAV] MailExceptions.OperationException: Sync of Rogers IMAP/ failed due to error: Rogers IMAP (Not Found on Accelerator)
01:45:59
01:45:59
01:45:59 Not Found on Accelerator
01:45:59
01:45:59
01:45:59
01:45:59
01:45:59
01:45:59 Description: Your request on host “caldav.calendar.yahoo.com” was not found.
01:45:59 Check the location and try again.
01:45:59
01:45:59
01:45:59
01:45:59 Rogers IMAP [CalDAV] Synchronizing items: Sync of Rogers IMAP/ finished: 0 uploaded, 0 deleted, 0 obsolete, 0 items, 0 downloaded
or
00:56:09 Rogers IMAP [CalDAV] MailExceptions.OperationException: Subfolder synchronization for folder “Calendar” failed with following error: Not Found on Accelerator
00:56:09 Rogers IMAP [CalDAV] Synchronizing subfolders: Done
00:56:09 Rogers IMAP [CalDAV] Synchronizing items: For folder Rogers IMAP/
00:56:10 Rogers IMAP [CalDAV] MailExceptions.ConnectionException: The underlying connection was closed: The connection was closed unexpectedly. —> System.Net.WebException: The underlying connection was closed: The connection was closed unexpectedly.
00:56:10 at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
00:56:10 at MailClient.CalDav.ProtocolCommands.RequestCommand.Execute(HttpWebRequest httpRequest, CancellationToken cancellationToken, Action1 logBody) 00:56:10 at MailClient.CalDav.ProtocolCommands.XmlRequestCommand.Execute(HttpWebRequest httpRequest, CancellationToken cancellationToken, Action
1 logBody)
00:56:10 at MailClient.CalDav.ProtocolCommands.Connector.RunCommand(CalDavAccount account, ICommand command, CancellationToken cancellationToken)
00:56:10 — End of inner exception stack trace —
00:56:10 at MailClient.CalDav.Synchronizer.SynchronizeItemsCommand.Execute(WorkerStatus status)
00:56:10 at MailClient.Commands.Command.Process(WorkerStatus status)
The error messages don’t happen every time eMClient picks up mail, but the “running dots” issue happens quite frequently, and is annoying because the program often “hangs” after that.
Ports are 993 for outgoing, 465 for SMTP incoming, using SSL/TLS on legacy port.
Does anyone have any ideas about where to look for the answer? Thanks,
Nigel
