PROBLEM WITH IN/OUT MAIL
Problem with Mail: don’t coming and exit.
Setting are correct, as requested by libero mail:
SMTP is:
HOST smtp.libero.it
Porta 465
IMAP is:
HOST imapmail.libero.it
Porta 993
but don’t work. What I have to do?
Thanks a lot for support
Hi, sorry for the late reply.
Your server settings look fine (IMAP 993 and SMTP 465 both use SSL/TLS). To find out what is going wrong, please tell us:
  1. Your eM Client version (Menu > Help > About) and Windows or Mac version.
  2. The exact error message you get when receiving and when sending.
  3. Can you log in to Libero webmail with the same password? Did you change the password recently?
  4. Is the security setting for both servers set to SSL/TLS (not STARTTLS)?
To send us logs privately (please don’t post them here):
  1. Go to Menu > Settings > Advanced > Logging, click Clear Logs and tick IMAP and SMTP under the Libero account, plus Global modules > Authentication.
  2. Restart eM Client and repeat the problem. Note the time.
  3. Click the Send Logs… button in the same section and mention the link to this forum topic in your message.
  4. Untick the modules again afterwards.
Best,
eM Client Team
