problem with Google Calendar recurring monthly events
I believe there is a problem with google calendar recurring events, once a month .
I get a popup every day instead of once a month.
Can you dismiss the popup reminders?
Yes I can dismiss the dlg.
I guess the cause of the problem was that the event was created in outlook, sync to google. google calendar said that it could not handle the event, so I edited in google. emclient imported calendar daily,instead of bimonthly.
So I completely deleted the event, created it new with google calendar, now everything ok.
Thank you for your support, sorry to disturb.
I am glad you solved it.
