problem with function send to recipient from file
Hi, I’ve got windows 10 (ver 1709) and even though I’ve set emclient as the default app for emails, when I click on a “send to recipient” file tell me no client present; if you install thunderbird, it works properly and open this client. has happened to someone? How can I fix it?
In Windows 10, go to Settings > System > Default Apps
Scroll down to the bottom and choose Set defaults by app
Scroll down to eM Client and choose Set this program as default
That should set eM Client to all of it’s defaults.
Thanks for reply: emclient is already predefined (and also the mailto function)
Seems to be a problem with 1709. Have a look at this thread, where it was recently discussed in detail.
https://forum.emclient.com/emclient/topics/right-click-send-to-mail-doesnt-work-with-windows-10-home…
very thanks! work with add .reg
