Problem with Copy to folder and Move to folder with the latest eM Client V9.x for Windows and Mac.
If you choose either of the above and select a folder to copy or move an email to, (it’s then remembered in the dropdown) under the copy to folder or move to folder to preselect next time which is great. That works fine.
However if you then click Copy to folder or Move to folder without using the previous dropdown folder locations and choose “a different folder location” to move another email to, the next time you select the original folder location in the dropdown it doesn’t go back to the original folder location in the dropdown and instead goes to the new location you choose when you “directly clicked” on copy to folder or move to folder.
So the dropdown previous folder locations are forgotten if you then copy or move another email later to a different folder location by directly clicking on copy to folder or move to folder. So the previous dropdown copy to folder or move to folder locations should allways go directly to those same locations no matter what you do later.
