Problem with Calendar file
Some time after upgrading to version 7.0.27943.0, (at least some of) my past recurring events are no longer displayed on the calendar. They are still in the database because I can find them by doing a search for them using a text phrase that is in each event, however they no longer have the title of the event, and if I try to edit them, em Client crashes. I also can’t export my calendar file to an ics file. When I try, I get the following error message: An error occurred when saving items. Saving to file “(location of file)” failed with error “Object reference not set to an instance of an object.”  How do I recover my calendar file, the missing events, and enable export?
(I also have the error text from the crash report, if that might be helpful.)
Error text from crash:
eM Client (7.0.27943.0)
Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.42000
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. —> System.NullReferenceException: Object reference not set to an instance of an object.
   at MailClient.UI.Schedule.CommonOperations.ShowEditScheduleObjectDialog[TItem](TItem item)
   at MailClient.UI.Controls.controlEvents.EventItemBehaviour.OnOpen(Object sender, EventArgs e)
   at MailClient.UI.Controls.controlItemList2.controlDataGrid\_CellDoubleClicked(Object sender, DataGridCellClickedEventArgs e) &nbsp;&nbsp; at MailClient.UI.Controls.ControlDataGrid.ControlDataGrid.OnDoubleClick(EventArgs e) &nbsp;&nbsp; at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) &nbsp;&nbsp; at System.Windows.Forms.Control.WndProc(Message& m) &nbsp;&nbsp; at System.Windows.Forms.ScrollableControl.WndProc(Message& m) &nbsp;&nbsp; at System.Windows.Forms.ContainerControl.WndProc(Message& m) &nbsp;&nbsp; at System.Windows.Forms.UserControl.WndProc(Message& m) &nbsp;&nbsp; at MailClient.UI.Controls.ControlDataGrid.ControlDataGrid.WndProc(Message& m) &nbsp;&nbsp; at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) &nbsp;&nbsp; at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) &nbsp;&nbsp; at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) &nbsp;&nbsp; at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) &nbsp;&nbsp; at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) &nbsp;&nbsp; at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) &nbsp;&nbsp; at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) &nbsp;&nbsp; at MailClient.Program.\<\>c.<main>b__62_3()<br> --- End of inner exception stack trace ---<br> at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)<br> at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)<br> at System.Delegate.DynamicInvokeImpl(Object[] args)<br> at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)<br> at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)<br> at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)<br> at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)<br> at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)<br> at System.Windows.Forms.Control.InvokeMarshaledCallbacks()<br> at System.Windows.Forms.Control.WndProc(Message&amp; m)<br> at System.Windows.Forms.ScrollableControl.WndProc(Message&amp; m)<br> at System.Windows.Forms.Form.WndProc(Message&amp; m)<br> at MailClient.Common.UI.Forms.BaseForm.WndProc(Message&amp; m)<br> at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message&amp; m)<br> at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message&amp; m)<br> at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)<br> at Xilium.CefGlue.Interop.libcef.run_message_loop()<br> at MailClient.Program.&lt;&gt;c.<main>b__62_2()<br> at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)
" rel=“nofollow” target="_blank">http://emclient.com/ns/report">;
eM Client
7.0.27943.0
false
4.0.30319.42000
mscorlib
mscorlib.dll
100667723
mscorlib
InvokeMethod
mscorlib
System.Object
target
mscorlib
System.Object[]
arguments
mscorlib
System.Signature
sig
mscorlib
System.Boolean
constructor
ffffffff
0
mscorlib.dll
100680823
mscorlib
mscorlib
System.Object
obj
mscorlib
System.Object[]
parameters
mscorlib
System.Object[]
arguments
7
c0
mscorlib.dll
100664788
mscorlib
System.Delegate
DynamicInvokeImpl
mscorlib
System.Object[]
args
d
75
System.Windows.Forms.dll
100666634
System.Windows.Forms.Control+ThreadMethodEntry
tme
cf
ae
100666633
mscorlib
System.Object
obj
20
62
mscorlib.dll
100677969
mscorlib
RunInternal
mscorlib
executionContext
mscorlib
System.Threading.ContextCallback
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
79
a6
mscorlib.dll
100677968
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
mscorlib
System.Boolean
preserveSyncCtx
0
15
mscorlib.dll
100677967
mscorlib
Run
mscorlib
executionContext
mscorlib
callback
mscorlib
System.Object
state
2b
40
100666632
tme
37
94
100666635
58
127
100666928
WndProc
System.Windows.Forms.Message&
m
655
144
100676306
WndProc
m
34
2f
100672215
WndProc
m
26f
69
MailClient.Common.UI.dll
100663775
WndProc
m
36
45
100684775
System.Windows.Forms.Control+ControlNativeWindow
OnMessage
m
0
12
100684778
WndProc
m
8e
34
100674667
DebuggableCallback
mscorlib
System.IntPtr
hWnd
mscorlib
System.Int32
msg
mscorlib
System.IntPtr
wparam
mscorlib
System.IntPtr
lparam
25
5d
Xilium.CefGlue.dll
100666825
Xilium.CefGlue
run_message_loop
ffffffff
0
MailClient.exe
100688544
MailClient
MailClient.Program+<>c
<Main>b__62_2
41
bf
MailClient.ExceptionUtils.dll
100663314
Filter
MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate
body
MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate
filter
mscorlib
System.Action1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]</type><br> <name>handler</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>22</nativeoffset><br> <br> </stack><br> <data></data><br> <inner><br> <exception><br> <type>System.NullReferenceException</type><br> <message>Object reference not set to an instance of an object.</message><br> <source>MailClient</source><br> <stack><br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100668951</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Schedule.CommonOperations</type><br> <name>ShowEditScheduleObjectDialog</name><br> <genericarguments><br> <argument><br> <assembly>MailClient</assembly><br> <type></type><br> </argument><br> </genericarguments><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type></type><br> <name>item</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>3d1</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100691507</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlEvents+EventItemBehaviour</type><br> <name>OnOpen</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>sender</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>f</offset><br> <nativeoffset>1e</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100677081</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlItemList2
controlDataGrid_CellDoubleClicked
mscorlib
System.Object
sender
MailClient
MailClient.UI.Controls.ControlDataGrid.DataGridCellClickedEventArgs
e
0
2d
MailClient.exe
100680982
MailClient
OnDoubleClick
mscorlib
System.EventArgs
e
12e
2d3
100666912
WmMouseUp
m
System.Windows.Forms.MouseButtons
button
mscorlib
System.Int32
clicks
13c
1f5
100666928
WndProc
m
62f
913220
100676306
WndProc
m
