problem viewing local folders and read email
I am helping my father in law. He has emclient v10. The local folders and any previously read email are not showing. I have tried all the obvious stuff like checking local folders is ticked and repairing the inbox. I think the problem may have come from a mcafee virus scan as I found emclient mail in the quaratine, but on restore it has not made any difference. Any ideas anyone?
I have found the problem, mcafee quarantined the main mail_data.dat file from local folders. I have restored but the email is still not visible. Can anyone advise next steps please?
Could be “there is more than the mail_data.dat file that needs to be restored” or whatever happened their might have “corrupted the database” and needs all the previous database folder restored.
So if you have been making eM Client backups which by default are in “Documents / eM Client” folder, then you can restore a recent backup when you know the Local Folder data was there via “Menu / File / Restore” and any new mail etc since the backup will update when eM Client reconnects.
If you have not been making regular eM Client backups then you can alt restore the previous hidden database folder if you have a copy of the user profile backed up on another drive.
So you would close eM Client and rename your current database to eg: eM Client-Old and then copy the backed up eM Client hidden database to the same location and reopen eM Client and your Local Folder data should all appear.
On Windows, go to C:\Users%username%\AppData\Roaming\eM Client
On macOS, go to /Users/User Name/Library/Application Support/eM Client
See the following support blog below.
Thankyou for your reply. I will try the partial restore. Unfortunately we do not have a recent backup, wont make that mistake again,
Here is what has happened:
  1. Mcafee ran a virus scan
  2. Mcafee quarantined the mail_data.dat
  3. Father in law didnt know about this and entered emclient next day
  4. emclient created a new database and re-downloaded all available data from email provider (last 14 days)
  5. old email not visible
  6. I restored the mail_data.dat back original location
  7. Emclient is still not seeing the old email
I think the database files in the emclient folder are out of synch.
Appreciate the help
  • Father in law didnt know about this and entered emclient next day* emclient created a new database and re-downloaded all available data from email provider (last 14 days)* old email not visible* I restored the mail_data.dat back original location * Emclient is still not seeing the old email
There would also i suspect be other files within the hidden folder database that have then been affected when the mail_data.dat file was quarantined and opened without that file. So even restoring the mail_data.dat later is probably not enough to restore the local folder mail.
Yes as eM Client is now setup again as new, then without a backup.zip file, a partial restore from the hidden folder database would probably be the only way to restore the Local Folder mail if your father in law has a copy of his computer user profile on another drive or has a complete hard-disk image on another drive prior to the mail_data.dat file being removed.
Suggest in future setup either automatic periodic backups via “Menu / Settings / General / Backup” which by default save a dated backup.zip file in the “Documents / eM Client” folder. Or you can manually backup anytime via “Menu / Backup” if you don’t want the automatic backup.
