Thanks, Gary! Sometimes the easiest solutions are the hardest to find… I’ve spent 30 minutes trying to work out a solution for this error, all to no avail.
Then I did what you suggested and it solved the problem in 30 seconds
It’s a bit worrying that the error appeared in the first place, as it shows something’s not quite right with the latest eM update.
