Problem sending mail
I am able to receive incoming mail from mypostoffice account but not able to send mail.
The “From” label on the send screen shows “no account”.
Robert Briggs
please look in Tools - Accounts - your account if there is SMTP tab and if yes then look in it and write me Port and security policy
regards
Jan
Thank you Jan
Tool - Accounts takes me to IMAP screen which shows
Host: imap.mypostoffice.co.uk
Security Policy: Use SSL/TLS if available
Any advice to make this work would be much appreciated.
Robert
I need that port number as sometimes old ports are used and are not compatible with modern security policy.
regards
Jan
Port Number is 143
Regards
Robert
really 143? are you looking in IMAP or SMTP? Is SMTP tab even in your account settings?
regards
Jan
