Hi friends,
I have the following problem. Pls help me to rectify those problems.
*After I send the mail, I cant see that mail in sent items. Some mails will send only after one week.
*Having problems in date.
aren’t the mails you are missing in Sent folder in Outbox folder? What do you mean by “Having problems in date” ?
Milos Kovalcik.
Hi Milos Kovalcik,
Mails missing in sent folder. Then If i send a mail now, It shows like it was sent in future.
The date is taken from settings on your computer so please check what date is set on your PC.
I understand that your mails are missing in Sent folder but aren’t they in Outbox folder?
Milos Kovalcik.
No I checked the system date. It is correct. But problem in mail date. Only 2 out of 10 mails not saved in sent folder. I checked in outbox folder but there also i cant found.
Regards
Suhas Rao K.S.
can you please send us some screenshots describing your situation?
