When exporting contacts from EM Client into VCF files, why does it duplicate every contact in the resulting VCF file(s)? This behaviour seems to be the same if one exports to one VCF or separate VCF Files.
How exactly did you export the contacts? By right clicking on a contact or by File - Export - Export contacts as VCF?
It is to do with Groups, if you have contacts that are members of more than one group, then the export is not “clever” enough to not export them again.
The only way round the problem is to export from the subgroup explicitly and not just the Contacts Folder
Sorry, to answer your original question, exporting by using File Export
OK, thank you for the info - I have forwarded it to our developers so hopefully they will take a look on this issue soon.
