Hi I have two aol accounts but one of them have 8053 old email know when I select it and click delete it said its deleting but nothing happens after this. Lucky I did not buy this as if I did this would drive me mad. As you can see from link http://imgur.com/TAIZoHs the older email are not deleting even through it said it doing it can you please fix this and then I will buy this until you fix this I will not buy this.
Hi Syfer,
does this issue happen even if you try to delete only one of the older emails? Do any error messages pop up about not being able to delete them from the server?
hi no their are no error message at all. it said its will take some time then when it finished its still their very strange.
Hi Syfer,
and does deleting just a single message work or not?
hi yes it does work by deleting one message at a time but deleting all of the message does not work.
