System.IO.IOException: Er zijn geen bestanden meer.
bij System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
bij System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption)
bij System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
bij DbRepair.Form1.CheckCorruption()
bij DbRepair.Form1.Check(Object state)
That looks like a computer geek question, but personally I would try uninstalling eM client and reinstalling a clean copy and try again, may work, maybe not, no harm in trying
Hi Saeys,
did you try uninstalling the program completely and installing again? If so, did you uninstall using the Windows Programs window? If no, try a reinstall using the MSI file of the version you were previously running.
If you need the files of any of the older releases I could provide the installation files.
what is ? and how can i reinstall the msi file i use vista
i have uninstal em client via configuration of windows
but noting works
Hi Saeys,
MSI file is the installation file you use in any version of Windows to install an application. If you run our MSI file again while eM Client is already installed, it will give you the option to repair or remove eM Client.
Try these older msi files (for installation and to remove eM Client again) :
version 6.0.23181> http://www.emclient.com/dist/v6.0.231…
version 6.0.23421 > http://www.emclient.com/dist/v6.0.234…
Hi Olivia;
I follow your recommendation, but when I tried to update it shows the same error.
Please help.
