Hi Metin,
there should not be an error message like that concerning an update. I think it’s more likely the error message indicating that you have used the same license on more than one devices.
Please disable the license from the device that you are not currently using either in Help > License or through the licensing server at http://licensing.emclient.com/ (must be accessed through IE).
If you believe this is not the case and are using your license on one device only, please attach a screenshot of the error message. Thank you.
Hi Metin,
I see, I didn’t know you still used version 5. Strange that the application asked for an update, as v5 did not have any recent updates.
Please uninstall eM Client and run the latest v5 installer - http://www.emclient.com/dist/v5.0.200… (all previous releases of eM Client are always available on our website www.emclient.com/release-history).
