SERIOUS PROBLEM WITH PRIVACY When you make a new calendar entry, it over-rides the default privacy setting of the Google Calendar it is connected to. The default appears to be public, even if the calendar is set to be private. I’ve checked this several ways. The drop down menu for events (show as busy/tentative…etc) does not work on Google Calendar. If you check the box Private, then the event is uploaded to Google Calendar as private and people who have access to the calendar just see it as “Busy”. If you don’t do that, they can see everything, even if the calendar sharing options are free/busy.
thank you for the report - we will try to solve it as soon as possible.
Thank you - has this been fixed in the new release 4.0.14479.0?
No,
unfortunately we did not make it to version 4.0.14479.0 because of many other scheduled tasks.
Is the privacy problem bug fixed in 4.0.15010.0?
the only solution is to use “Private” checkbox.
