How can I print a custom view of my contacts? I need to print a sorted list of specific fields from my contacts. I can create a custom view which shows it just fine, but I cannot print just what appears in the custom view. Any help would be appreciated.
Select the contacts you want to print. Right click on them and choose Print selected.
Hope it helps you.
George,
Thank you for your reply. I can print the selected contacts, but it prints all the contact information. I need to print a list with just certain fields showing. Is there any way to print with just the fields selected in the custom view?
Thanks
It is not possible at the moment. I will add this to our list of feature requests.
