Print On Both Sides Missing and Doesn’t Work
Ignores my printer’s default of Print On Both Sides.
Print On Both Sides only works if I go through more steps and use “Print using system dialog.” I get both sides. How can I fix this?
miércoles 19 agosto 2026 :: 2011hrs (UTC +0100)
Hey @ironef
It is the same for me and I believe this is correct.
If I am wrong someone will say.
skybat
¡Buena suerte!
Hablo español, luego portugués, inglés, francés, italiano y alemán
con conocimientos de varios otros idiomas incluidos griego y ruso
Print On Both Sides Missing and Doesn’t Work. only works if I go through more steps and use “Print using system dialog
Yes agree with @skybat “that is normal for a lot of printers” where by default you don’t always see all the options and have to press Print using system dialogue and is not an eM Client issue.
That also happens for me in Windows 11 (25H2) with many different apps using a eg: Xerox 4 colour laser printer or a Brother laser printer.
This is normally to do with the OS or Printer driver in some way which interfaces to apps.
