Why is there no preview of tasks?! Pain in the xxx to have to open each one to see contents when just need to skim through… Preview Pane please!
If you are using the Agenda in the right side-bar, you can preview the task by hovering over it with your mouse:
Or by hovering over the task in your calendar:
But I agree that the Tasks section needs a preview pane like the other sections, so I changed this thread to a Feature Request.
Thanks for the feedback but I don’t use Agenda (prefer the space for active work rather thanextraneous ‘dross’) and even so you only get a partial view of the task which means you then need to go into Tasks and open up the specific one… 3 actions!
Thanks for upgrading the post, look forward to the resolution!
PS it’s also VERY easy to accidently mark the task as complete and it disappears! Bonkers…
Just unselect Hide completed tasks, and it will re-appear - as if by magic!
