In Notes, any way to prevent the note title from printing??
Thanks,
James
Thanks,
James
martes 22 septiembre 2020 :: 2201hrs (UTC +01:00)
Hi James…
You can try this though I suspect it is printer dependant, I have 2 printers an HP Laser and a Canon Inkjet, both on my private network and this procedure worked with both, however, there is no guarantee that it will work for you as when I logged into my company network also with an HP Laser it did not because the configuration settings were grayed out.
Here’s what I did, select the note and click print, in this popup select your printer at the top, deselect show header/footer, at bottom of the window click ‘Print using system dialog’, this should take you to your printer configuration window, if available you can again deselect show header/footer - this allowed me to print without the title.
Good Luck
Russ
Unfortunately there is no option in my printer dialog to show or hide header/footer.
Just wondering.
Thanks,
James
miércoles 23 septiembre 2020 :: 1521hrs (UTC +01:00)
Hi James…
Such is life…
Russ
