skusil som i vycistit AppData uzivatela a zadat ucty nanovo - chyba pretrvava
eM Client (6.0.24316.0)Windows: Microsoft Windows NT 6.1.7601 Service Pack 1, Framework: 4.0.30319.42000
System.ArgumentOutOfRangeException: Year, Month, and Day parameters describe an un-representable DateTime.
at System.DateTime.DateToTicks(Int32 year, Int32 month, Int32 day)
at MailClient.UI.Controls.Calendar.MonthCalendarView.RefreshScrollbarProperties()
at MailClient.UI.Controls.Calendar.MonthCalendarView.ViewActivate(Boolean refreshvisibledays)
at MailClient.UI.Controls.Calendar.CalendarView.controlCalendar_ViewTypeChanged(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.DelegateViewTypeChanged.Invoke(Boolean refreshvisibledays)
at MailClient.UI.Controls.controlCalendar.set_ActualViewType(ViewType value)
at MailClient.UI.Forms.formMain.ActivateEventView()
at MailClient.UI.Forms.formMain.tsbMonthView_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at MailClient.Common.UI.Controls.ToolStripEx.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at MailClient.Program.b__4()
at MailClient.ExceptionUtils.ExceptionUtils.Filter(BodyDelegate body, FilterDelegate filter, Action1 handler)<br><br><br><report xmlns="<a href=" http:>" rel="nofollow" target="_blank">http://emclient.com/ns/report">;<br> <product><br> <name>eM Client</name><br> <version>6.0.24316.0</version><br> </product><br> <silent>false</silent><br> <environment><br> <osversion>Microsoft Windows NT 6.1.7601 Service Pack 1</osversion><br> <frameworkversion>4.0.30319.42000</frameworkversion><br> </environment><br> <exception><br> <type>System.ArgumentOutOfRangeException</type><br> <message>Year, Month, and Day parameters describe an un-representable DateTime.</message><br> <source>mscorlib</source><br> <stack><br> <frame> <br> <method><br> <modulename>mscorlib.dll</modulename><br> <metadatatoken>100664580</metadatatoken><br> <assembly>mscorlib</assembly><br> <type>System.DateTime</type><br> <name>DateToTicks</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>year</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>month</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>day</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>b2fd71</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100690913</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.Calendar.MonthCalendarView</type><br> <name>RefreshScrollbarProperties</name><br> <parameters></parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>65</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100690894</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.Calendar.MonthCalendarView</type><br> <name>ViewActivate</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>refreshvisibledays</name><br> </parameter><br> </parameters><br> </method><br> <offset>a6</offset><br> <nativeoffset>c1</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100690425</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.Calendar.CalendarView</type><br> <name>controlCalendar_ViewTypeChanged</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>refreshvisibledays</name><br> </parameter><br> </parameters><br> </method><br> <offset>8</offset><br> <nativeoffset>25</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100690695</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlCalendar+DelegateViewTypeChanged</type><br> <name>Invoke</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Boolean</type><br> <name>refreshvisibledays</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100690541</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlCalendar</type><br> <name>set_ActualViewType</name><br> <parameters><br> <parameter><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Controls.controlCalendar+ViewType</type><br> <name>value</name><br> </parameter><br> </parameters><br> </method><br> <offset>2c</offset><br> <nativeoffset>44</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693265</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formMain</type><br> <name>ActivateEventView</name><br> <parameters></parameters><br> </method><br> <offset>eb</offset><br> <nativeoffset>17d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100693312</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.UI.Forms.formMain</type><br> <name>tsbMonthView_Click</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>sender</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>50</offset><br> <nativeoffset>79</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100679166</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>RaiseEvent</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Object</type><br> <name>key</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>15</offset><br> <nativeoffset>6d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100678245</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripButton</type><br> <name>OnClick</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>17</offset><br> <nativeoffset>40</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100679101</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>HandleClick</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>3b</offset><br> <nativeoffset>c3</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100679110</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>HandleMouseUp</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.MouseEventArgs</type><br> <name>e</name><br> </parameter><br> </parameters><br> </method><br> <offset>c6</offset><br> <nativeoffset>201</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100679087</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>FireEventInteractive</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItemEventType</type><br> <name>met</name><br> </parameter><br> </parameters><br> </method><br> <offset>46</offset><br> <nativeoffset>88</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100679086</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItem</type><br> <name>FireEvent</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.EventArgs</type><br> <name>e</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStripItemEventType</type><br> <name>met</name><br> </parameter><br> </parameters><br> </method><br> <offset>c9</offset><br> <nativeoffset>8ec5c0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100678124</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStrip</type><br> <name>OnMouseUp</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.MouseEventArgs</type><br> <name>mea</name><br> </parameter><br> </parameters><br> </method><br> <offset>6f</offset><br> <nativeoffset>b1</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100666912</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>WmMouseUp</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.MouseButtons</type><br> <name>button</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>clicks</name><br> </parameter><br> </parameters><br> </method><br> <offset>184</offset><br> <nativeoffset>27e</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100666928</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>62f</offset><br> <nativeoffset>913a2c</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100676306</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ScrollableControl</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>34</offset><br> <nativeoffset>2f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100678175</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ToolStrip</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>e3</offset><br> <nativeoffset>49</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.Common.UI.dll</modulename><br> <metadatatoken>100663395</metadatatoken><br> <assembly>MailClient.Common.UI</assembly><br> <type>MailClient.Common.UI.Controls.ToolStripEx</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>11</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100684775</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control+ControlNativeWindow</type><br> <name>OnMessage</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>0</offset><br> <nativeoffset>12</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100684778</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Control+ControlNativeWindow</type><br> <name>WndProc</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Message&</type><br> <name>m</name><br> </parameter><br> </parameters><br> </method><br> <offset>8e</offset><br> <nativeoffset>34</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100674667</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.NativeWindow</type><br> <name>DebuggableCallback</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>hWnd</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>msg</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>wparam</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>lparam</name><br> </parameter><br> </parameters><br> </method><br> <offset>25</offset><br> <nativeoffset>5d</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100681139</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.UnsafeNativeMethods</type><br> <name>DispatchMessageW</name><br> <parameters><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.NativeMethods+MSG&</type><br> <name>msg</name><br> </parameter><br> </parameters><br> </method><br> <offset>ffffffff</offset><br> <nativeoffset>0</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100684342</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ComponentManager</type><br> <name>System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.IntPtr</type><br> <name>dwComponentID</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>pvLoopData</name><br> </parameter><br> </parameters><br> </method><br> <offset>173</offset><br> <nativeoffset>24c</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100684388</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoopInner</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>1df</offset><br> <nativeoffset>154</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>System.Windows.Forms.dll</modulename><br> <metadatatoken>100684387</metadatatoken><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.Application+ThreadContext</type><br> <name>RunMessageLoop</name><br> <parameters><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Int32</type><br> <name>reason</name><br> </parameter><br> <parameter><br> <assembly>System.Windows.Forms</assembly><br> <type>System.Windows.Forms.ApplicationContext</type><br> <name>context</name><br> </parameter><br> </parameters><br> </method><br> <offset>14</offset><br> <nativeoffset>4b</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.exe</modulename><br> <metadatatoken>100675740</metadatatoken><br> <assembly>MailClient</assembly><br> <type>MailClient.Program</type><br> <name><Main>b__4</name><br> <parameters></parameters><br> </method><br> <offset>17</offset><br> <nativeoffset>4f</nativeoffset><br> <br> <frame> <br> <method><br> <modulename>MailClient.ExceptionUtils.dll</modulename><br> <metadatatoken>100663314</metadatatoken><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils</type><br> <name>Filter</name><br> <parameters><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+BodyDelegate</type><br> <name>body</name><br> </parameter><br> <parameter><br> <assembly>MailClient.ExceptionUtils</assembly><br> <type>MailClient.ExceptionUtils.ExceptionUtils+FilterDelegate</type><br> <name>filter</name><br> </parameter><br> <parameter><br> <assembly>mscorlib</assembly><br> <type>System.Action
1[[System.Exception, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]
handler
0
22
MailClient.exe
C:\PROGRAM FILES\eM Client\MailClient.exe
MailClient.exe
MailClient.exe
6.0.24316.0
eM Client
eM Client
6.0.24316.0
False
False
False
False
False
Jazykovo neutrálne
ntdll.dll
C:\Windows\SYSTEM32\ntdll.dll
ntdll.dll
ntdll.dll.mui
6.1.7600.16385 (win7_rtm.090713-1255)
NT Layer DLL
Microsoft® Windows® Operating System
6.1.7600.16385
False
False
False
False
False
Angličtina (USA)
MSCOREE.DLL
C:\Windows\SYSTEM32\MSCOREE.DLL
mscoree.dll
mscoree.dll
4.0.40305.0 (Main.040305-0000)
Microsoft .NET Runtime Execution Engine
Microsoft® .NET Framework
4.0.40305.0
False
False
False
True
False
Angličtina (USA)
KERNEL32.dll
C:\Windows\system32\KERNEL32.dll
kernel32
kernel32
6.1.7601.18015 (win7sp1_gdr.121129-1432)
Windows NT BASE API Client DLL
6.1.7601.18015
False
False
False
False
False
Slovenčina (Slovensko)
KERNELBASE.dll
C:\Windows\system32\KERNELBASE.dll
Kernelbase
Kernelbase
6.1.7601.18015
False
False
False
False
False
ADVAPI32.dll
C:\Windows\system32\ADVAPI32.dll
advapi32.dll
advapi32.dll.mui
6.1.7601.19131 (win7sp1_gdr.160116-0600)
Advanced Windows 32 Base API
6.1.7601.19131
False
False
False
False
False
Angličtina (USA)
msvcrt.dll
C:\Windows\system32\msvcrt.dll
msvcrt.dll
msvcrt.dll
7.0.7601.17744 (win7sp1_gdr.111215-1535)
Windows NT CRT DLL
7.0.7601.17744
False
False
False
False
False
Angličtina (USA)
sechost.dll
C:\Windows\SYSTEM32\sechost.dll
sechost.dll
sechost.dll.mui
Host for SCM/SDDL/LSA Lookup APIs
6.1.7600.16385
False
False
False
False
False
Angličtina (USA)
RPCRT4.dll
C:\Windows\system32\RPCRT4.dll
rpcrt4.dll
rpcrt4.dll.mui
Remote Procedure Call Runtime
6.1.7600.16385
False
False
False
False
False
Angličtina (USA)
mscoreei.dll
C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll
mscoreei.dll
mscoreei.dll
4.6.1055.0 built by: NETFXREL2
4.6.1055.0
False
False
False
True
False
Angličtina (USA)
SHLWAPI.dll
C:\Windows\system32\SHLWAPI.dll
SHLWAPI
SHLWAPI.DLL.MUI
Shell Light-weight Utility Library
6.1.7600.16385
False
False
False
False
False
GDI32.dll
C:\Windows\system32\GDI32.dll
gdi32
gdi32
6.1.7601.19091 (win7sp1_gdr.151208-0600)
GDI Client DLL
6.1.7601.19091
False
False
False
False
False
Angličtina (USA)
USER32.dll
C:\Windows\system32\USER32.dll
user32
user32
6.1.7601.17514 (win7sp1_rtm.101119-1850)
Multi-User Windows USER API Client DLL
6.1.7601.17514
False
False
False
False
False
LPK.dll
C:\Windows\system32\LPK.dll
LanguagePack
LanguagePack
6.1.7601.18985 (win7sp1_gdr.150901-1452)
Language Pack
6.1.7601.18985
False
False
False
False
False
Angličtina (USA)
USP10.dll
C:\Windows\system32\USP10.dll
