When connecting to an Echange Web Server, I always get a Timeout message when trying to send email with attachments larger than approx 3-4 MBytes.
Would it be possible to let us set a Timeout Time (in seconds) manually?
Is it possible to set it yet maybe using Windows Registry (regedit) or editing some configuration file?
Thanks a lot
Kind regards
Does the send complete, despite the message? If yes, you can always turn off the messages by going to menu/tools/settings/general and in the “Operations Window” section, uncheck “Show window when error occurs”.
I realize this is just a workaround and does not solve the underlying issue, but there is no way to set the timeout parameter.
Unfortunately the send operation is not completed…
