My EmClient did open anymore, They open a window wich says Verify the database, then appear fail. In Details they say Error SQLite error no such table:mail_data.LocalMailContents
Do you know what it tis?: And where is my database, my mailboxes?
Cheers
I am afraid the only solution is restoring your data from a backup.
Your database is located here:
C:\Users%Current User%\AppData\Roaming\eM Client (Vista/Win7)
C:\Documents and Settings%Current User%\Application Data\eM Client (XP)
Hey George, but i dont have a backup and i traying to reinstall and have the same error
George, i tryed to reinstall, but the same error hapened with the new eM client
If you do not have backup, delete the database folder and run eM Client with blank database. Afterwards set your accounts and everything should synchronize automatically from the server (if you use IMAP).
but what ́s the name of the database folder…
The name is “eM Client” and it is located here:
