Please help ASAP
What if i have purchase 8 license together from one laptop and only one email id the link is shared only on one email id and then how i should proceed for the other 7 laptops?
The email address is simply the address used to register the license, it does not mean that you can only use the application with that address. So you can use the same activation key on all 8 laptops regardless of what email address they are using.
Hello Dipika,
Exactly as Gary said, you can use the activation key on 8 laptops regardless the email address it was registered to. If you still have troubles with activation, you can contact me at: [email protected].
RusselĀ
