Please fix the rules issue
After 2 updates the rules still fail to apply on software startup
Regards
Hi, we have a fix for this issue prepared for the next update (not the current 10.0.3447 unfortunately) but there is a workaround that can resolve the bug without an update.
Go to Menu>Accounts
Open the POP or IMAP tab of the affected account.
Change any detail in this tab - for example the number of days the messages should be kept on the server or the sync options etc. (You can change this back later of course)
Save this change.
Restart eM Client.
Now the rules should be applied correctly and you can reverse any settings change you made previously.
The issue should be resolved in this (not yet public) version
https://www.emclient.com/dist/v10.0.3475/setup.msi
