Please fix pop up reminders
Since installing v11.0.1267, my appointment reminders are not popping up when they should. When the appointment reminder window pops up, it shows old reminders that I did not dismiss because I didn’t see them.
Hello, can you please check that reminders are on for the calendar: right-click the calendar, choose Properties… and make sure “Show reminders” is ticked.
If it’s already on, could you let us know:
  • Your account type for this calendar
  • Whether the reminder was set in eM Client or in another app
  • Whether it affects all events or only some of them
Show reminders is ticked. The account type is Event. All reminders are set in eM Client. As best as I can tell it affects all events.
I have exactly the same problem. After installing v11 I first got a gazillion notification about thousands of old calendar event and then they stopped working altogether.
I have all notifications and reminders set to use emclients own notification (not the system ones) and they are enabled EVERYWHERE.
It has just stopped working which is kind of a show stopper for me.
