For the love of all that’s useful WHY is the scrollbar so narrow on the app??
Not sure if this is a recent change or I’m just noticing it now that my mouse wheel broke, but trying to get the scrollbar to appear and target the cursor on it is a game I’m getting sick of. Yeah, I get it - it looks pretty and modern and saves a few pixels of screen space but gods is it a PITA.
To adjust the scrollbar you can edit the following entry in your Theme XML file.
You will need to change False to True or True to False to suit your requirement
False
OR
You can use the eMC Theme Editor:
Menu ->Tools ->Theme Editor
When the Editor opens scroll down in the left hand column to:
Scrollbar ->Click ->Either check or clear the entry for UseSystemScrollbar ->SAVE
IMPORTANT - Before you do anything: Menu ->Backup
If you do not understand any of this ASK do not GUESS
I have been meaning to post about this for ages, so you beat me to it Kiki. The narrow scroll bar is really difficult to use due to its size. Plus, if you so much as breath on the scroll bar it zooms up or down in such large increments/at such speed that it is very hard to navigate where you are. It drives me nuts, which is a shame because EMC is a great product in every other respect.
I’m afraid a solution which talks about amending a theme XML file doesn’t work for me, as I’m not technical. I have tried but don’t know where to save the renamed theme, plus I am not comfortable doing so given all the warnings about “ask not guess”.
Once you have the file, go to Menu > Settings > Appearance > Themes and click on Import.
Select this file, and it will appear at the bottom of the list of existing themes.
