Hi
I’m evaluating eM Client 6.0.21372.0 and, even if I like your program, I have two issues that prevent me to buy your program :
I received plain text emails from unix hosts and they are not indented/aligned as expected or as they are displayed in Thunderbird/Postbox. It seems that you remove all tabs
I have an imap account for which I always get “Connecting to xxx failed” for imap. But if I retrieve mail manually, this is ok. I’m using TLS for imap and smtp. This account works fine on Thunderbird/Postbox with the same settings.
I can see that in the logs :
11:58:41 xxx [IMAP] MailExceptions.ConnectionException: Cannot open folder “{0}”.
11:58:41 (Connection terminated)
11:58:41 at MailClient.Imap.ConnectionPoolEntry.SelectFolder(Folder value, Boolean force)
11:58:41 at MailClient.Imap.ConnectionPool.AcquireConnection(Folder mailFolder, Boolean idle, Boolean forStore)
11:58:41 at MailClient.Imap.ConnectionPool.AcquireFolderConnection(Folder mailFolder)
11:58:41 at MailClient.Imap.Synchronizer.SynchronizeMessagesCommand.ExecuteInternal(WorkerStatus status)
11:58:41 at MailClient.Imap.Synchronizer.ImapCommand.Execute(WorkerStatus status)
11:58:41 at MailClient.Commands.Command.Process(WorkerStatus status)
Nicolas
