Hi I have a problem with version 7.0.26567.0
When receipts mails with attached PDF files do not appear anywhere.
I test with another mail program and yes it is attached.
I’m having the same issue
Hi, I try to update the program and with the version 7.0.26687.0 know works fine.
Maybe are a small problem solved with this version.
I hope it helps you.
That worked, thank you
