Paste does not keep the format
Hi everyone,
I’ve been having trouble pasting text from Word into the forum. For the past few days, when I try to paste, I only see the paste option, which doesn’t retain any formatting so I can paste only the plain text.
Does anyone have any suggestions on how to fix this issue? Any help would be greatly appreciated.
Thanks
You can change the option in Menu > Settings > Mail > Compose:
Or you can use the format option in the tooltip:
First of all, thank you for the quick answer.
I already adopted solution 1, on solution 2 I can select only the second and third option but not the fist one…
If the option looks like this, it means the source is not formatted:
Hi Gary.
It is like this. What do you suggest?
I meant it is like that image but I cannot select the first icon that should be the right one.
I am afraid I need to change the sw :frowning:
