Outlook agenda not imported
I’ve imported outlook contacts, emails, and even gmails. Gmail agenda imports fine, but outlook agenda is missing completely. I use outlook365. I’m interesting in buying the program, but this feature should work. Any help?
Hi Alex, not completely sure what you’re referring to. When importing data from Outlook, did you select, import accounts or import data from a selected PST file?
If you want to import local data from Microsoft Outlook, please use the import data from selected pst file option and navigate to the existing PST file. Select the folders you want to import and proceed with the import.
Hope this helps,
Paul
