I am attempting to connect to my exchange email account. When I set up I receive the error
"[Exchange Web Services] An attempt to connect to email address failed. This could be caused by temporary server unavailability or incorrect settings. Do you want to check the settings?)
The error log is below
8:20:40 AM Online state: changed to online due to NetworkAvailability
7:31:03 AM [email protected] [Offline Address Book] Synchronizing folder list
7:31:04 AM [email protected] [Exchange Web Services] Synchronizing folder list
7:36:05 AM [email protected] [Exchange Web Services] MailClient.Accounts.ConnectionException: The operation has timed out. —> System.Net.WebException: The operation has timed out.
7:36:05 AM at MailClient.Protocols.Exchange.ExchangeGenericCommand.Execute(WorkerStatus status)
7:36:05 AM — End of inner exception stack trace —
7:36:05 AM at MailClient.Commands.Command.Process(WorkerStatus status)
7:36:06 AM [email protected] [Offline Address Book] MailClient.Accounts.ConnectionException: The operation has timed out. —> System.Net.WebException: The operation has timed out.
7:36:06 AM at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
7:36:06 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.ReadBytes(Stream stream, Byte[] buffer, Int32 count)
7:36:06 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.UncompressLzx(Stream fullFile, Stream outputFile)
7:36:06 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.GetFolderList(Folder homeFolder, CancellationToken cancellationToken)
7:36:06 AM at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass10_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
7:36:06 AM at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
7:36:06 AM — End of inner exception stack trace —
7:36:06 AM at MailClient.Commands.Command.Process(WorkerStatus status)
7:36:58 AM [email protected] [Exchange Web Services] Synchronizing folder list
7:37:27 AM [email protected] [Offline Address Book] Synchronizing folder list
7:37:28 AM [email protected] [Exchange Web Services] Synchronizing folder list
7:37:29 AM [email protected] [Exchange Web Services] Synchronizing folder '[email protected]/Inbox/'
7:42:29 AM [email protected] [Offline Address Book] MailClient.Accounts.ConnectionException: The operation has timed out. —> System.Net.WebException: The operation has timed out.
7:42:29 AM at System.Net.ConnectStream.Read(Byte[] buffer, Int32 offset, Int32 size)
7:42:29 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.ReadBytes(Stream stream, Byte[] buffer, Int32 count)
7:42:29 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.UncompressLzx(Stream fullFile, Stream outputFile)
7:42:29 AM at MailClient.Protocols.OfflineAddressBook.OabFolderSynchronizer.GetFolderList(Folder homeFolder, CancellationToken cancellationToken)
7:42:29 AM at MailClient.Protocols.Common.FolderSynchronizer.<>c__DisplayClass10_0.b__0(WorkerStatus status, CancellationToken cancellationToken)
7:42:29 AM at MailClient.Protocols.OfflineAddressBook.OabGenericCommand.Execute(WorkerStatus status)
7:42:29 AM — End of inner exception stack trace —
7:42:29 AM at MailClient.Commands.Command.Process(WorkerStatus status)
7:42:45 AM [email protected] [Exchange Web Services] MailClient.Accounts.ConnectionException: The operation has timed out. —> System.Net.WebException: The operation has timed out.
7:42:45 AM at MailClient.Protocols.Exchange.ExchangeGenericCommand.Execute(WorkerStatus status)
7:42:45 AM — End of inner exception stack trace —
7:42:45 AM at MailClient.Commands.Command.Process(WorkerStatus status)
7:45:19 AM [email protected] [Exchange Web Services] Sending email
7:45:19 AM [email protected] [Exchange Web Services] Sending email: Test
7:46:19 AM [email protected] [Exchange Web Services] Synchronizing folder '[email protected]/Sent/'
7:46:38 AM [email protected] [Exchange Web Services] MailClient.Accounts.ConnectionException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. —> System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. —> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. —> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
7:46:38 AM at System.Net.Sockets.Socket.EndReceive(IAsyncResult asyncResult)
7:46:38 AM at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult)
7:46:38 AM — End of inner exception stack trace —
7:46:38 AM at System.Net.Security._SslStream.EndRead(IAsyncResult asyncResult)
7:46:38 AM at System.Net.TlsStream.EndRead(IAsyncResult asyncResult)
7:46:38 AM at System.Net.PooledStream.EndRead(IAsyncResult asyncResult)
7:46:38 AM at System.Net.Connection.ReadCallback(IAsyncResult asyncResult)
7:46:38 AM at MailClient.Protocols.Exchange.ExchangeGenericCommand.Execute(WorkerStatus status)
7:46:38 AM at MailClient.Commands.Command.Process(WorkerStatus status)
7:50:40 AM [email protected] [Exchange Web Services] Synchronizing folder list
7:50:40 AM [email protected] [Offline Address Book] Synchronizing folder list
7:50:42 AM [email protected] [Exchange Web Services] Synchronizing folder '[email protected]/Inbox/'
7:51:04 AM [email protected] [Exchange Web Services] MailClient.Accounts.ConnectionException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. —> System.Net.WebException: The underlying connection was closed: A connection that was expected to be kept alive was closed by the server. —> System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. —> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond
7:51:04 AM at System.Net.Sockets.Socket.EndReceive(IAsyncResult asyncResult)
7:51:04 AM at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult)
7:51:04 AM — End of inner exception stack trace —
7:51:04 AM at System.Net.Security._SslStream.EndRead(IAsyncResult asyncResult)
7:51:04 AM at System.Net.TlsStream.EndRead(IAsyncResult asyncResult)
7:51:04 AM at System.Net.PooledStream.EndRead(IAsyncResult asyncResult)
7:51:04 AM at System.Net.Connection.ReadCallback(IAsyncResult asyncResult)
7:51:04 AM at MailClient.Protocols.Exchange.ExchangeGenericCommand.Execute(WorkerStatus status)
7:51:04 AM at MailClient.Commands.Command.Process(WorkerStatus status)
