Old emails are gone
Good afternoon. I have EmClient 6 and my messages are suddenly gone. But the EmClient folder is about 5.8GB. More precisely, the mail_data.dat file. Are my old messages in this file? If so, how can I get them back?
Hello Axia,
It seems that something happened to the location of your database. That probably caused that eM Client created a blank new database. You can find the original database file in the folder using https://support.microsoft.com/en-us/h…
In eM Client you will set the database path to the original file in Menu > Tools > Settings > General > Storage
NOTE: if you are making any changes in database location, do it with eM Client application closed because it might cause sudden crash.
I hope this was helpful.
Russel
Good Morning. Unfortunately when it was imported yet nothing appeared
Hello Axia,
After you displayed hidden files in the eM Client folder, did you find the original database? Then just to be sure, check the path set in eM Client to lead correctly to the old database.
Russel
