I am attempting to add my office 365 account and I’m receiving an authentication error.
I am absolutely certain that my credentials are correct. I can login online with them and they work perfectly in other mail clients such as outlook.
Is there anything I can do to resolve this?
Hi Michael,
Which version of eM client are you using?
If it’s v7.2.34711 or earlier , obtain the latest version (v7.2.34959) from the main page https://emclient.com/ and install. Then try again.
Hope this helps.
Peter
Hi Peter
The version I am using is 7.2.34974.0 for Mac.
I have reinstalled and the problem persists. I have also tried on another Mac and I have the same problem.
Regards
Michael
Hi Michael,
Sorry - was not aware you are on Mac.
Please go here
https://forum.emclient.com/emclient/topics/reaction-to-the-outlook-com-authentication-problem
Mac version is 7.2.34959
Wonder if you can also get it from here - it says latest version
https://emclient.com/download-mac
(For Windows that version is on the Home page and wonder if they did the same for Mac )
Regards
Peter
Hi Peter,
The first link to the application once installed, returns the same authentication prompt.
The second link to the application once installed, times out to the servers.
Regards
Michael
I tried to reinstall a second time and it worked!
Thank you
Regards
Michael
Hi Michael,
Thanks for the feedback…
I’m glad you didn’t give up …
Peter
