not updating unread count
it does not take into account the removal of unread messages when displaying number of unread messages. Thus, it stays to, say 3, even if only one unread message remains actually.
Restarting the app updates well the number.
send us your IMAP log please. Go to Tools - Settings - Logging, check IMAP under the problematic account and restart eM Client. Then try to simulate the issue and send us the logs using the same logging settings window. Thank you.
I can not simulate (every time you take the car to the garage, as if by chance it works!)
I will try to set logging as soon as I feel like it will behave the same.
Thanks
Nouveau ! Cliquez sur les mots ci-dessus pour apporter des modifications et voir d’autres traductions. Ignorer
Google Traduction pour les entreprises :Google Translator Toolkit
Gadget Traduction
Outil d’aide à l’export
Désactiver la traduction instantanée
À propos de Google TraductionMobileConfidentialitéAideEnvoyer des commentaires
