I use W10 64Bit with a very fast Intel SSD with more than 1.5GB Speed. Always when i start MClinet a Errormessage ist Displayd; when i type ignore the second Message is “no Error” an i see by the “Mail” Tab a “!”. When i type Send/Receive every things is ok. This Bug have i since i start with EMclient. Look also ATT
Hi Peter,
unfortunately, the picture of the log you added isn’t very helpful, as it doesn’t show the same problem as the error and is cut off.
When this error occurs again, go to the log tab, click inside, copy all with Ctrl + A shortcut and copy and paste the log here.
Thank you.
Best regards,
hier ist the full log but is see only ok Connection
Hi Peter,
I’m afraid you forgot to send the log?
