Not junk move to parent inbox?
Hi!
I’m just in the process of transitioning from Postbox - I have 10 email accounts and to manage the junk (e.g. check nothing important was marked incorrectly as junk) I had a unified folder for all my junk folders. Postbox then had a handy function “Not Junk” that moved an email from this folder back to the corresponding parent inbox.
I have created a search folder in eM Client that also collates my junk - is there a command or quick action I can use to quickly unmark as junk and move back to the parent inbox?
It’s not a major problem since if not I can probably create a rule per account (e.g. move to Inbox A, move to Inbox B etc.) but this is a bit messy! Alternative I can just drag to the favourites. Problem is I prefer the multiline view and this doesn’t include the account name unless there’s a way to enable this?
Thanks,
Richard
I agree, that would be useful.
