I have configured emclient with my isp email account - exactly as it was in my old email client (I’ve used both Thunderbird and Outlook). Regardless of this my email will not send. It just sits in the outbox. I have also tried using the option to send immediately, and have clicked the send/receive (all, selected etc) and the send only options. Again no matter what I have tried it will not send. I also confirmed that with those settings I can send successfully from the old email client today. So it is not an ISP problem. This is urgent as if I am not able to correct it I will not be able to use the program.
could you please describe account settings in the SMTP tab (Host, Port, Security policy and selected Authentication method)
Best Regards
Sure: Host: smtp.cogeco.ca; Port: 25; Security Policy: Don’t Use secure connection; Selected Authentication method: Use identity credentials.
I hope this helps. I took these settings directly from the email program I was last using, and they do work.
The instructions from your provider seem to be little scarce [1]. Please try setting the authentication method to “Anonymous”. Hope this helps.
That worked - THANKS!!!
