Hi. I just installed EM Client and have this odd issue:
When I get an email from my husband, it arrives from two sources: (1) his email address, and (2) “[email protected] on behalf of” him. This does not happen with anyone else’s emails. And it didn’t happen when I was using Outlook 2007.
Anyone have an explanation why this occurs and how I can stop it?
You should answer (yourself) some questions to investigate this:
Changed your husband to emClient, too?
Have you changed your email provider (or your husband)?
Is there possibly an email redirection set to get sent mail into an additional post box?
It is possible to set up a configuration that a sent mail always is sent as a copy to another/your own account. Maybe there the sender address is wrong/missing (not sure if this is possible)
I am no “Outlook specialist” therefore this is just an idea: Did you import your postbox data from Outlook? Maybe there a redirection for copies into a folder or something like that was set and is now invalid. PST import generally has some interesting effects…
Beta version 8.0.1481 fixed this issue, so if you are using a beta version, upgrade to the latest version available in the Release History.
I am not sure if it was fixed in recent version 7 releases, but if you are on version 7, upgrading to the latest version 7 in the Release History might also fix the problem.
