No way to play a sample of the notification sounds
Usually in email programs there is some sort of play button to play the nomination sound for an entry so that you can hear what that sound file sounds like. Is there no way in eMClient to do this?
jueves 06 agosto 2026 :: 1313hrs (UTC +0100)
Hey @pcguy
As far as I am aware you will need to open the “SOUND” folger
in the eM Client installation folder then double click the files,
you can add your own sound files if you wish.
skybat
¡Buena suerte!
Hablo español, luego portugués, inglés, francés, italiano y alemán
con conocimientos de varios otros idiomas incluidos griego y ruso
