No Umlaute(äöü) in calendar part of eM Client
Hi all
Im new on eM Client and have an issue with the calendar, Umlaute will not shown correctly. I think a known problem.
When i start to create a new apointment the letters will shown corectly
Then when i save the appointment the letters are displayed in another charset.
When i check on the calendar webapp from my hoster the letters are still correct.
Is there someone who can help? Then you are heartly invited to help solving this problem.
Im using version 6.0.23421.0 on a win 10 x64 machine.
best regards and thanks in advance
Oliver
Thanks for your competent Support. You helped me to choose Outlook again to work with.
best regards
Oliver
Hi Oliver,
I’m sorry for the late reply, I have been trying to recreate your issue but haven’t been able to do it, as the symbols still appear correctly for me no matter which way I try and then forgot to get back to you.
I understand you’ve given up on the issue, but if you decide to get back, I’d like to perhaps know which email service you’re using, is this the gmail calendar or CalDAV?
Best regards,
