I can’t find LICENSE when clicking on the HELP key? ONLY COMES UP WITH CONTENTS F1 AND ABOUT
It should be there in Menu > Help > License.
It was there when I went back and I have hopefully activated my license, are you able to check that I’ve done it correctly Many thanks
Sorry Lorraine, this is a user forum, so we are not able to check the licensing server.
But you should be able to do that yourself. In Menu > Help > License it should indicate the details of your license. That would mean it is activated.
If you have a Pro License, you can use the license manager to see the status of the license.
Trying to activate license but there is not menu dropdown in the version I have downloaded. Has it changed location? Is there a new way to activate license?
If you are using a beta version ( 7.2.x) then there is no activation option as beta versions do not need to be licensed.
