Hi
i downloaded version 7 beta, but it tells me my trial license is expired.
how is that possible? i’ve never run any version of em on this computer.
how to fix?
thx
Hi
how to fix?
thx
I had the same problem and I was running version 6 demo. I had to uninstall and re-install version 6 so I could download my emails. Something not right with version 7 beta
Hi Johny,
unfortunately the BETA does not have a trial version. You need to use it with a license.
Which license do I need?
Can I use a license number of the version 6?
OK done. You have to enter the key of Release 6.
