Need license activation code
I have purchased emclient a few months ago and it works great. Today due to software problems I had to format and reinstall my OS. I downloaded emclient again and installed it. I restored my emclient backup but now emclient is not activated. I do not have my activation code, is it possible for you to send it to me.
your license should be inside the email you received upon purchase. If you cannot find it, I can reset your credentials, which will generate an email with new password to the licensing server and your license key.
I’ll need to know the email under which you registered, seeing as the one you signed up under on the forums doesn’t seem to be in our database.
You can send the request to [email protected]
Best regards,
