eM Client uses 100mb memory. It sits there checking my mail in the tray with no fuss. I have tried many email clients and they mostly use 300mb, and for what? That is enough for my laptop fan to run all the time, with eM Client I don’t have that problem. I usually only have Brave browser and eM Client running.
Long may eM Client, a sensible email client continue! Thanks for making it.
Hi @Justin_Tuijl
We appreciate you using eM Client and thank you for your feedback. We developed version 11 for users like you, based on feedback and feature requests that we received so we are glad it’s finally released. Please keep testing it and do let us know of any issues that come up.
Gee 100MB Ram in memory is very good. Ive never got close to that.
Using eM Client V11.1054 on Win 11 Pro i get average 330MB Ram used when idle, and on Mac OS 27 average 812MB when idle. But im ok with that as i have 16GB ram so not an issue.
I will leave my Windows installation for many hours and see if it comes down.
Aye, I just a have a cheap laptop
I can’t confirm that. It certainly depends on individual usage.
With my 19 linked accounts
Having 19 accounts shouldn’t normally make any differance.
If your getting a GB or more of ram usage, then either “your mail or other items are not all synced yet” so using more memory till finished, or “you have more than one instance open” as some users do, or “its not idle” and still has ongoing operations that are not completed yet.
If its a Mac too the amount of Ram usage can also climb if you eg: close it via the “Red Dot” and don’t fully exit the program and then reopen the program. It will usually just keep climbing higher due to how the Mac OS works. So if you have a Mac, make sure to close it completely.
Oh well, version 11 uses near 300mb so I reverted to 10. Looks like I shall never upgrade above 10.
