My events are not displaying in eM Client. I can enter an event in eM Client and it will show up in my Gmail calendar but it does not show up or display in eM Client.
Hi, what version of eM Client are you currently using? Can you tell me the exact version number from Help > About.
Also can you try right clicking the calendar folder and select Properties > Repair and click on the repair button?
I have the latest version. It’s okay now. My Google calendar is syncing fine now. The only thing now it I have a contact group called coworkers. I have no such group in Google contacts and I can’t seem to delete the group in eM Client. Is this a part of the program or should I be able to delete it?
Hi, yes there are some pre-set groups in eM Client after the installation, but you should be able to delete the category if you go to Tools > Categories and Remove the category…
Hope this helps,
