E-Mail only comes in, after I do a Diagnostics on it. Thanks for any help. Otherwise great E-Mail Client, thank you
Hello Les,
what email account does this issue happen on? What mail protocol does it use - POP/IMAP/Exchange? Check the Tools>Accounts sections.
Hi Olivia,
Thanks for your help, I use POP3 With o2 Account, it worked fine before I upgraded to Windows 10. Thanks again. So at the moment, if E-Mail doesn’t come through, I just do a Diagnostics and it says fix it, then it works again. So it must be in the set up somewhere, much appreciated for a reply.
