Hi, unfortunately eM Client install the application to a default folder after you download, however you should be able to run the installer in command line with a different path parameter.
Please use this in the command line in order to install the application in a different folder:
msiexec /i setup.msi MAILCLIENTINSTALLLOCATION=
Hope this helps,
thanks paul. it would be good if users can make a more gui interface of this.
can you transmit to developers.
when you say
“msiexec /i setup.msi MAILCLIENTINSTALLLOCATION=”
is this correct
msiexec /i setup.msi MAILCLIENTINSTALLLOCATION=f:\users\username
or
msiexec /i setup.msi MAILCLIENTINSTALLLOCATION=“f:\users\username”
thanks danny
Hi Danny,
the second one is correct.
Best regards,
